Anyone know the trick to reset the “tire pressure” error message on the dash, when you change the air pressure in your tires?
The advice in the manual is not working.
Pressing the reset button under the dash until the correct message is displayed, then driving the car immediately, is not working.
The car now has been returned to 2 bar (29 PSI) that the manual has as the OEM PSI, & I reset the button again today, then drove to work 5 miles, & it still has not reset the error message.
I don’t want to drive the car the rest of my ownership with a Tire Pressure Error message on my dash in place of the RPM display.
Any tips? Please help a brother out
Tire Pressure Reset issue
Re: Tire Pressure Reset issue
Unplugging the battery apparently cleared it!
Thanks
Thanks
