Cruise Control system - anyone have it?
larrysing63
Post by larrysing63 »
Cruise Control?
It is mentioned in the "Accessories" section of the New Car Features PDF that I located at century.trinom.org
But I can't find it in my car.
So apparently it is an option on the 2nd Gen Century. Anyone have it? Is it on the stalk like other old Toyotas?
I'm spoiled to it, and if mine does not have it, I'm going to look to getting an aftermarket CC added.
Has anyone done that?
Re: Cruise Control system - anyone have it?
I don't have it but I do know it was an option - I think you might actually be better off installing an aftermarket system than trying to retrofit the factory one, because IIRC it is restricted to 105kmh and you can't increase it.
Doughboy
Post by Doughboy »
There was a post on FB of someone fitting a LS400 Cruise control thing. I can't find the post, and gave up looking after 25 seconds.
1997 GZG50
1990 HDJ81
larrysing63
Got it, installed, working! Thanks!
pedroboe@gmail.com
Post by pedroboe@gmail.com »
larrysing63 wrote: Thu Apr 25, 2024 6:00 pm Got it, installed, working! Thanks!
How did you do it? Just got a century myself.
larrysing63
You have to buy a stalk, install the stalk, and once the stalk is in, the cruise works.
95 96 97 LEXUS LS400 STEERING COLUMN CRUISE CONTROL SWITCH OEM (1120)
The hard part is finding the correct cover with the hole in it.
I never did find the right one. I combined 2 different ones, trimming one with my Dremel tool and then attaching the little rubber grommets from the other cover onto that one.
I think these are the two parts I used:
45186-50030-C0
45187-50030-C0
