Hello,
I'm working on a g50 import for a customer. The rear seat audio and ac controls dont illuminate or funtion at all. The seat controls do work fine. before I dive into this, is there some type of enable switch that needs pushed ? Any other advice would be great.
thanks
Turbofob
Rear seat audio and ac controls
Re: Rear seat audio and ac controls
it could be the fuse, The Rear Function controls has a fuse in the fusebox located in the boot, you'll need google translate to translate the Japanese. Inside the boot lift the carpet up and there should be a removable piece for the left side, take it out and the fuse box should be near the back wall. If it's not that maybe just rip the rear seats out and have a look at the wiring from there.
