For the sake of educating myself I changed the water pump on my 1997.
It's straight forward in many ways. But you must remember to remove the pulley because there's 1 bolt hiding behind.
Here are a few pics of the new one. I have the thermostat and inlet housing attached.
You can see the two half attached. I didn't remove any of those bolts or separate it. The old one water pump and new one just goes in one piece.
Water Pump
Water Pump
1997 Toyota Century - Eternal Black <202> - Seiko Clock
Re: Water Pump
Backside of the water pump. Two lower outlets require gaskets.
Larger:
GASKET(FOR WATER INLET HOUSING)
90301-24019
Smaller:
RING, O (FOR WATER PUMP)
90301-46006
A picture of between the "V" of the engine where the water pump lies.
Larger:
90301-24019
Smaller:
90301-46006
