Page 1 of 1
Information about the G60 Century
Posted: Sat Jan 06, 2024 8:19 am
by _centuriEC03
This thread will compile all the currently known information about the UWG60 platform. I will update this thread as time goes on. Hope this helps
Break Down on the Vehicle model code
DAA - UWG60AEXGH
DAA - Vehicles that meet the 2005 standard exhaust gas reduction level of 75%
UWG60 Vehicle Equipped with the 2UR-FSE Power Plant and Rear Wheel Drive
A - Toyota Century
E - Sedan
X - Continuously automatic floor change L110 (electronic continuously variable transmission)
G - Standard Grade
H - DOHC, Direct injection, EFI
Factory Specification colors
225 - Kamui Eternal Black
8J9 - Mashu Shireen Blue Mica
3P6 - Asuka Blackish Red Mica
1C0 - Seika Radiant Silver Metallic
Seat Types
Gray Wool (Zuikyo) with Ash heather (brown wood trim)
Brown Wool (Zuikyo) with Ash heather (brown wood trim)
Beige Wool (Zuikyo) with Ash heather (brown wood trim)
Black Leather (Gokubei Leather) with Ash heather (brown wood trim)
Fromage (Gokubei Leather) with Ash heather (brown wood trim)
Black Leather Gokubei Leather) with Ash heather (silver wood trim)
Fromage (Gokubei Leather) with Ash heather (Silver wood trim)
DAA - UWG60
SIZE
Length - 5355mm
Width - 1930mm
Height - 1505mm
Wheelbase 3090mm
Tread Front - 1615mm
Tread Rear - 1615mm
Tire - 225/55/R18 98H Bridgestone REGNO GR001 Century Exclusive Design
Wheel/Offset - 18inch 7.5J offset+32 PCD120 5 Holes
Indoor Length - 2165mm
Indoor Width - 1605mm
Indoor Height - 1185mm
Minimum ground Clearance 135mm
VEHICLE WEIGHT
Vehicle Weight - 2370KG
Capacity - 5 People
Gross Vehicle - 2645kg
PERFORMANCE
Minimum Turning Radius 5.9M
ENGINE
Model - 2UR-FSE
Number of cylinders and arrangement - 90° V8 cylinder, vertical installation
Total displacement - 4968cc
Inner diameter X stroke - 94x89.5
Compression ratio - 11.8
Fuel used - Unleaded Premium Petrol Or Gasoline
Fuel cut rotation speed at high rpm - 6800 rpm
Maximum output KW or PS/RPM - 280KW 381PS/6200rpm
Maximum Torque NM or kgf・m - 510NM 52.0kgf・m /4000rpm
Firing Order - 1-8-7-3-6-5-4-2
Fuel tank Capacity - 82L
HYBRID MOTOR
Format - 1KM
Kinds - AC synchronous motor
Maximum output KW PS - 165KW 224PS
Maximum Torque NM kgf・m - 300NM 30.6 kgf・m
TRANSMISSION
Model - L110 Type
Type - Electric type (internal combustion engine), electronically controlled planetary gear type (electric motor)
Shift Position PRNDS
Speaker Setup
20 Speaker Layout =
9 cm instrument panel center speaker
2.5cm instrument panel side speaker x2
9cm instrument panel side speaker x2
18cm Front door speaker x2
5cm x 9cm ceiling speaker x2
2.5cm rear door speaker x2
9cm rear door speaker x2
16cm rear door speaker x2
20cm rear woofer
2.5cm rear satellite speaker x2
9cm rear satellite speaker x2
Brand New Vehicle Price = 20,080,000 Yen (18,254,545 Yen Excluding Tax) That is around 8,000,000 Yen more than the G50 Series Century.
Main Equipment
225/55R18 98H tires & 18×7 1/2J noise reduction aluminum wheels (with colored center ornament)
LED cornering lamp
7-inch rear multi-operation panel
The screen differs depending on the option installed.
Rear seat LED reading light (brightness adjustable)
11.6-inch rear seat entertainment system & tower console
Blind Spot Monitor (BSM *1 )
*1.BSM: Blind Spot Monitor
Luggage Space
It has a capacity of 484L
UWG60 Procession Vehicle
Posted: Wed Jan 17, 2024 12:13 pm
by _centuriEC03
Changes over normal UWG60:
No window switches
No rear aircon vents
No roof (obviously)
Custom rear pillar center console with analog clock
Exterior Color
Interior Color/ Wood trim
UWG60 Procession Vehicle Interior
Posted: Wed Jan 17, 2024 12:14 pm
by _centuriEC03
Just more photos of the UWG60 Procession Vehicle
