50 series information refresh Welcab information
50 series Century generation information compiled into one place. Please do not comment on this thread as I will update this slowly. This is a new thread from my existing one. I will ask the admin to delete the last one.
Background of the 50 Series Century
The 50 series Century was the first Century in over 30 years to recieve a complete overhaul. Engineers fused the suspension engineering of the UCF21 Celsior, developed Japans 1st V12 engine purely for smoothness, reliability & quietness. Styling was kept traditional while still keeping the hospitality & elegance.
Comparison from previous model VG45
Gained height 45mm
Front overhang gained 10mm
Wheelbase gained 15mm
Rear overhang lost by 25mm
Luggage height gained 50mm (trunk capacity 400L → 500L)
There is no change in length & width, it will give you the impression it has become thicker due to increased interior space & trunk capacity
Dimensions
Length - 5270mm
Width - 1890mm
Height - 1475mm
Weight differs from variant
Wheelbase - 3025mm
Front tread - 1575mm
Rear tread - 1575mm
Tyre/Tire - 225/60/R16 98H
Rim offset - 16 x 7JJ + 45
Minimum ground clearance - 135mm
Vehicle capacity - 5 people
Turning radius 5.7m
Steering type
Rack and pinion
Steering gear Ratio 18.7
Main brake type Front – Ventilated disc 4-pod opposed piston with hydraulic vacuum booster
(Cylinder inner diameter 42.8mm x 4)
Main Brake Type Rear – ventilated disc single pod floating caliper with hydraulic vacuum booster
(Cylinder inner diameter 38.1mm)
Gained height 45mm
Dimensions
Length - 5270mm
Width - 1890mm
Height - 1475mm
Wheelbase - 3025mm
Rear tread - 1575mm
Turning radius 5.7m
Steering type
Rack and pinion
Early Period
Early period (April 1997 - January 2005)
Model Codes
E-GZG50-AESGK (Standard specification column shift 4 Speed)
E-GZG50-AEPGK (Standard specification floor shift 4 Speed)
E-GZG50-AEPGK-X (Dual EMV specification floor shift 4 Speed)
E-GZG50-AESGK-X ( Dual EMV specification column shift 4 Speed)
GF-GZG50-AESGK (Standard specification column shift 4 Speed)
GF-GZG50-AEPGK (Standard specification floor shift 4 Speed)
GF-GZG50-AEPGK-X (Dual EMV specification floor shift 4 Speed)
GF-GZG50-AESGK-X (Dual EMV specification column shift 4 Speed)
TA-GZG50-AESGK (Standard specification column shift 4 Speed)
TA-GZG50-AEPGK (Standard specification floor shift 4 Speed)
TA-GZG50-AEPGK-X (Dual EMV specification floor shift 4 Speed)
TA-GZG50-AESGK-X (Dual EMV specification column shift 4 Speed)
Welcab
TA-GZG50-VQKKPX (Dual EMV specification floor shift 4 Speed)
TA-GZG50-VQKKSX (Dual EMV specification column shift 4 Speed)
TA-GZG50-VQKKP (Standard specification floor shift 4 Speed)
TA-GZG50-VQKKS (Standard specification column shift 4 Speed)
Model code breakdown
E-GZG50-AEPGKX or AESGKX
E - The code shows which Japanese emissions laws the vehicle complies with, this code was used on the Century from april 1997 to Nov 1998
GZG50 - Chassis code
A - Car model = Toyota Century
E - Body type = Sedan
P - Transmission type = 4 Floor shift transmission
S - Transmission type = 4 Column shift transmission
G - Grade (Standard)
K - Engine = DOHC EFI 1GZ-FE
X - In car type display = Dual EMV package
GF-AEPGKX or AESGKX
GF - The code shows which Japanese emissions laws the vehicle complies with, this code was used on the Century from november 1998 to April 2000
TA-GZG50 AEPGKX or AESGKX
TA - The code shows which Japanese emissions laws the vehicle complies with. this code used on the Century from 2000 to 2004
E - Body Type = Sedan
(If the model code for these earlier Centuries do not have an X, this means it's a standard grade model with an analog clock replacing the front infotainment screen).
Changes in the early years
November 1998
Model code changed from E-GZG50 to GF-GZG50
January 2000
Model code changed from GF-GZG50 to TA-GZG50 with 25% lower emissions
Front Screen has been made wider and larger
January 2001
Cold weather specification was introduced
May 2001
A negative ion generator was made standard on all models.
Wheel fairings were added to the bottom of the car to reduce air resistance, improve running stability & reduce wind noise.
July 2002
Toyota introduced the Welcab specification Century, features such as a rear left rotating seat (up to 90 degrees), larger assist grip, sliding footrest & increased door angle for injured or elderly people.
Engine
Model – 1GZFE V12 cylinder vertical installation
Inner diameter x stroke - 81.0 x 80.8
Total displacement – 4996cc
Compression ratio – 10.5
Maximum output KW/PS/RPM - 206KW 280PS/ 5200rpm
Maximum torque KW/KGM/RPM - 480NM/49KGM/4000rpm
Engine weight – 253KG (maintenance dry weight)
Firing order – 1-4-9-8-5-2-11-10-3-6-7-12
Fuel tank capacity 95L
Fuel - unleaded petrol (premium preferred)
Transmission E-GZG50 GF-GZG50 & TA-GZG50
Format – A342E electronically controlled 4 speed AT
1st Gear – 2.531
2nd Gear – 1.531
3rd Gear – 1.000
4th Gear – 0.753
Recession – 1.880
Final Reduction Ratio – 3.615
Weight
E, GF & TA Standard grade models - 1990kg
E, GF & TA Dual EMV grade models - 2000kg
Model Codes
Welcab
GF-AEPGKX or AESGKX
November 1998
January 2000
January 2001
May 2001
July 2002
Engine
1st Gear – 2.531
2nd Gear – 1.531
3rd Gear – 1.000
4th Gear – 0.753
Recession – 1.880
Weight
Export market Century
When the 50 series Century came out back in 1997, Toyota wanted to sell the Century in other markets. So they made two export market variants called GZG50L & GZG50 R
L - Left hand drive
R- Right hand drive
As far as I can tell from research, these export market Centuries did not sell well. An example would be in mainland China, the Century lasted 2 years (1999 - 2001) before the pulled it from the market. It was overshadowed by cars like the BMW 760LI priced around 2.5 million yuan, apparently only 2 were sold as a export market specification there. One owned by the Japanese embassy and the other owned by a rich man. According to some Chinese sources they do have alot more Centuries in the country including a VG45 limousine.
Countries sold in
Brunei
North Africa regions
Singapore
Thailand
Middle East
Hong Kong
China
Differences in market
Hong Kong was the only country to get fender mirrors outside of Japan (the rest got door mirrors)
Brunei had the lace curtains as standard
Speedometers were set to 250kmh not 180kmh like the domesticated Japanese ones
We are unsure when they stopped producing vehicles for the exported markets.
Model Code's
E-GZG50L-AEPGKW ( Left Hand Drive Export Market specification)
E-GZG50R-AEPGKW ( Right Hand Drive Export Market specification)
Model Code Breakdown
E-GZG50L or R - AEPGKW
L or R - L = Left Hand Drive R = Right Hand Drive
P - 4 Floor shift transmission
G - Grade (they don't have a grade)
K - DOHC EFI 1GZFE
W - Europe and general countries
Full english export market manual
http://century.trinom.org/
(This has all the diagrams, buttons etc in English)
For some markets you'll need the left hand drive headlights to comply with standards. Here are part numbers from the LHD Variant (E-GZG50L-AEPGKW)
Genuine Right Side Headlight: 81130-40050
Genuine Left Side Headlight: 81170-40050
L - Left hand drive
R- Right hand drive
Countries sold in
Brunei
Singapore
Thailand
Middle East
Hong Kong
China
Model Code's
K - DOHC EFI 1GZFE
CNG Gas Century
January 2003
Sold between January 2003 - January 2005 (2 year run)
(CNG Century) (Apart of the TA-GZG50 emissions regulations)
75% reduction in exhaust gases from 2000 standards (ultra-low exhaust gases) under the ministry of land, Infrastructure, transport & tourism's low-emission vehicle certification system (in-house measurements). These were primarily used as chauffeur driven vehicles & taxi's for VIP clients.
Fuel Used CNG (13A)
Maximum Output KW/rpm 190KW (258PS) 5200rpm
Maximum Torque NM/rpm 405Nm (41.3kg・m) 4000rpm
Model code's
TA-GZG50-AESGKC (CNG Gas Column shift 4 Speed)
TA-GZG50-AEPGKC (CNG Gas Floor shift 4 speed)
TA - The code shows which Japanese emissions laws the vehicle complies with. it had a two digit code & was used on the Century from Jan 2003 to Jan 2005
C- CNG gas 13A
Weight
TA-GZG50 (GNG GAS) model 2120kg
Not much are known about these CNG powered Centuries other than this
Fuel Used CNG (13A)
Model code's
C- CNG gas 13A
Weight
Middle Period
Middle period (January 2005 to August 2010)
Model Code's
DBA-GZG50-AETGK (Dual EMV specification Floor shift 6 Speed)
DBA-GZG50-AEWGK (Dual EMV specification Column shift 6 Speed)
DBA-GZG50-AETGK or AEWGK
DBA - The code shows which Japanese emissions laws the vehicle complies with, This code was used from 2005 to 2017 until the model change of the DAA-UWG60
E- Body type = Sedan
T = 6 Speed Floor Shift (Transmission type)
W = 6 Speed Column Shift (Transmission type)
G = Standard (Dual EMV)
K - Engine = 1GZ-FE DOHC EFI
(The DBA model code cancelled the standard specification from the E, GF & TA Century while making the 'Dual EMV' specification the only option)
Transmission DBA-GZG50 (Mid to Late Period)
Format – A761 E super intelligent 6 Speed AT
1st Gear – 3.296
2nd Gear – 1.958
3rd Gear – 1.348
4th Gear – 1.000
5th Gear – 0.725
6th Gear – 0.582
Recession 2.951
Final Reduction 3.461
Maximum Torque Suffered NM/KGM/rpm – 460NM/46.9/4000rpm (20NM torque decrease)
Weight
DBA-GZG50 Dual EMV 2050kg
Changes in the Middle period
January 2005
Changed model codes because of emissions reduction by 75% to DBA-GZG50
New & improved super Intelligent 6-speed automatic transmission (6 Super ECT) + sequential shifting reduced torque by 20NM
New LED Tail Lamps
With the adoption of SRS curtain shield airbags, the front seat headrests were made smaller & the longitudinal position adjustment knob has been moved from the outside to the inside
Ventilated Seats were installed in the seat cushion & seat back. There is an air intake vent on the door side of the seat back.
Removed standard model (Dual EMV is the only option)
Daigo Wealthy Green 6N9 was discontinued & Seika Radiant Silver Metallic 1C0 was added
January 2006
Genuine wood grain steering wheel and shifter options were added, price is different from floor shift to column shift.
Model Code's
1st Gear – 3.296
2nd Gear – 1.958
3rd Gear – 1.348
4th Gear – 1.000
5th Gear – 0.725
6th Gear – 0.582
Recession 2.951
Weight
January 2005
New LED Tail Lamps
January 2006
G51 Century Royal
G51 Century Royal G51 2006 to 2008
Specifications known so far:
Bulletproof glass
Extended wheelbase by 885mm
Traditional style washi (Rice paper headliner)
Granite style scuff plates
Special wool interior
Other undisclosed security measures
Vertical taillights
No rear Century badges
all of the parts on the car is exclusive to the G51
Each vehicle costed $500,000 USD to make or 52.5 Million Yen, Production was from 2006 to 2008. 3 Sedans and 1 hearse was made in total.
Each G51 Royal are registered with an imperial number, a silver plaque outside on the front grille & rear deck lid with the word imperial written on it & a number to signify the vehicle. Imperial Number 10 was assigned to the UWG60 convertible while Imperial Number 2 was assigned to a G51 Hearse
Overall Length 6150m or 242.1in
Overall Width 2050m or 81in
Height 1780m or 70in
Curb Weight 2920kg or 6440lb
Vehicle Capacity = 8
Bulletproof glass
Vertical taillights
- Attachments
- Imperial_Processional_Car.jpg (63.65 KiB) Viewed 101867 times
- imperial number.jpg (62.99 KiB) Viewed 101867 times
- CENTURY ROYAL-4-714403.jpg (48.45 KiB) Viewed 101867 times
G51 Century Royal Hearse
G51 Royal Hearse
- Attachments
- G51 Royal Hearse.png (355.64 KiB) Viewed 101857 times
- G51 Royal Hearse Rear.png (410.9 KiB) Viewed 101857 times
Middle Period continuation
This is the first continuation post from the Middle period 2005 to 2010
January 2007
Pull down handle on the ottoman seat was changed to chrome
January 2007
Century Premium
Century Premium was unveiled at the 2007 Tokyo Motor Show.
It now resides at the Kanto Jidosha Kogyo Higashifuji Factory the birthplace of the Toyota Century.
The Century Premium had an array of one off features including:
A fixed sunlight panel with wood surround and washi rice paper on glass.
Chrome Accents through out the interior
A Vertical Slatted Front Grille
A fixed Rear Centre Console with an extendable wooden table
Special Fromage (Cream) Wool
A special Analog Clock In between rear center air vents
Phoenix patterned lace curtains
Granite with Aluminum style Scuff plates
- Attachments
- pc12.jpg (66.56 KiB) Viewed 101855 times
- pc11.jpg (75.79 KiB) Viewed 101855 times
- pc3.jpg (76.98 KiB) Viewed 101855 times
Century Premium Interior
Inside the Century Premium pt1
- Attachments
- pc7.jpg (36.33 KiB) Viewed 101854 times
- pc4 - Copy.jpg (72.13 KiB) Viewed 101854 times
- pc1 - Copy.jpg (59.83 KiB) Viewed 101854 times
