On my 1997:
Fluid for Transmission, Power-Steering, and Engine Cooling Fan. Usually nicknamed "Dextron III or Toyota Type-III." But most of the Toyota dealership don't know what that is. If you ask for Toyota transmission fluid they will offer you WS or Type IV.
Subjectively: I use this for my 4 speed transmission. Type III has higher viscosity than Type IV. I find it really makes the fan and power-steering smooth & quiet.
AUTOMATIC TRANSMISSION FLIUD
00718-ATF00
Part numbers/links/instructions for consumables and such like
Re: Part numbers/links/instructions for consumables and such like
1997 Toyota Century - Eternal Black <202> - Seiko Clock
On my 1997, lots of vacuum piping!
I found the best approach is to order a bunch of cut-to-size piping. Apart from a few specialty vacuum pipes you can simply take off the existing pipe, size it against the fresh pipe and then cut it to length. My electrical wire cutters gave a clean, even cut.
HOSE
90999-92002
Here is a picture of a handful with the leftover pipes after I cut them.
HOSE
90999-92002
On my 1997:
Crush washers for Transmission pan plug. I usually buy a handful to keep on hand. On my Century (and LS400) I do a drain and fill of the ATF pan every few oil changes. Best to change the crush washer every time.
GASKET
35178-30010
GASKET
35178-30010
I don't have a Facebook account so I cannot access that link
Which key is this referencing? The key with the golden phoenix encased in a black plastic case?
ie: Or the full metal key with the engraved phoenix?
ie:
I'm looking for a spare (blank) key, either design is fine. Provided it has the phoenix. But I can't figure out what the product code is for these on Amayama
Does anyone else know?
Heres a link for the uncut full key and transmitter. https://en.impex-jp.com/parts/new/searc ... 9070-40240
PART NUMBER 89070-40240
